I installed both windows last night. There is a drivers side and passenger side regulator (I learned this the hard way). Also, if you're installing the cables and it seems excessively tight, you're probably doing it wrong. If you follow Papajams chart, and you have the cable regulator on the correct side of the car, it’s actually relatively easy. Nothing to be afraid of…
