1 - 11 of 11 Posts
I posted this is my main thread for my engine build but I wanted to post it here too for some more attention:
I have the alfaholics windage tray that bolts on between the block and the oil pan, however, I only have one gasket... I am better off getting a second gasket for both sides, using the gasket on only one side and then rtv on the other, or just rtv on both sides? If I do use only one gasket, should it go on the engine block side or oil pan side?
Thanks in advance!
The best approach is to use sealant on both sides and not use a gasket. A major benefit of the plate is strengthening the block. With the gasket on the other side, the pieces are more likely to move against one another.
Reactions: Salvispider
How is the plate connected to the main bearings, with half height nuts, pal nuts or no nuts?
I also got a windage tray sold without any fasteners.
I might use the gasket with RTV on the upper side as the surface is not flat every were (rear main bearing cap).
Discussion Starter · #4 ·
Mine came with half height nuts to attach over the bearing caps. I'll post a picture once I get it in
Discussion Starter · #5 ·
Thanks Erik! That actually makes a whole lot of sense
Discussion Starter · #6 ·
I ended up just putting rtv on both sides. Here's the picture of the half height nuts installed.
1675329
It's also worth noting that the alfaholics one is designed to be installed before the oil pump. As this forces you to install the pump with the front cover on which is much tougher I just modified it by cutting away enough material so that it can clear the pump.
If not flat around your rear main bearing cap you will have oil leaks, so needs to be fixed
If the block has been line bored or honed, the rear main cap has been cut and will shorter than the pan rail. Find a sheet of aluminum or steel the same thickness as the offset and cut a shim to make up the difference. Seal with RTV.
1 - 11 of 11 Posts
