1 - 10 of 10 Posts
Hi hope you are all find.
I have been trying to find out why is there a pink wire on my coil
It is going to a relay that should not be there
I have disconnect the wire for a trip downtown and did not do anything that I noticed
Moderator
1991 164L
What terminal on coil is pink wire added to? I suspect it would be on the terminal with green-black wire coming from ignition switch. Probably somebody wanted a keyed 12v power source for something. What terminal is pink wire going to on relay?
I want to post a photo but it's big
i'm not shore how to make it small enough ?
Moderator
1991 164L
Set up camera for VGA 640x480 format or crop photo to less than 700 width.
Filetype Max Filesize Max Width Max Height
bmp 249.0 KB 700 -
doc 97.7 KB - -
gif 249.0 KB 700 -
jpe 249.0 KB 700 -
jpeg 249.0 KB 700 -
jpg 249.0 KB 700 -
pdf 9.54 MB - -
png 249.0 KB 700 -
txt 97.7 KB - -
xls 9.54 MB -
You can also do like me and upload to either Picassa or Photo Bucket (they will automatically downsize) and then just paste the image link in your post. It makes it much easier.
Discussion Starter · #6 ·
So I have put them facebook (photos) Scj Siviour
I was hoping that would make them small
I use my phone to take the photos
Discussion Starter · #7 ·
Hi guys so the car got very hot today went I had the pink wire disconnected
about 120 c going through McDonald's or 'Macca's' in Australia
so The pink wire was put in because the main fan 40w fuse is blown
bloody cheep skate's
cheers
Moderator
1991 164L
40w? 40A maybe. I would guess your pink wire supplied power to fan relay energizing coil at pin 86 when key turned on not actual 40A fuse for fan power wiring. If added relay does not have a 40A fuse in wire going to pin 30 of relay that is dangerous.
Pink wire should have a 10A fuse in it to protect relay energizing circuit.
Discussion Starter · #9 ·
yes I agree with you mate.
So I work at (Autobarn) car parts shop so I have put a new 40A fuse and water proof fuse holder
some one tried to solder the old fuse back together HA HA
SOME PEOPLE SHOULD NOT OWN ALFAS. LOL
Now the ABS light is on the dash
it all happened in one day
not shore what's going on ? were a good place to start looking mate.
cheers Shane
I would start by turning off "Auto Correct" on your "Smart Phone." LOL :wink2:
Charles
1 - 10 of 10 Posts
