I have been researching the hei ignition module used with the
Marelliplex distributor. The module was designed by GM and is used in a GM distributor with a built-in coil.
It appears that GM does not use a resistor in their rotor. I would think that if the goal was to get as much energy to the spark plug as possible, adding a resistor to the rotor would be the last thing you would want to do.
Can anyone tell me the purpose of the 5k resistor in the rotor used on the Marelliplex ignition, and if anyone has run this distributor with a non resistor rotor.
Also, I am looking for a coil to replace the original Marelliplex coil. I would be interested to here what people have used successfully.
Thanks.
Larry
Thanks.
Larry
