Been working on my 78 spider and noticed that the oil has a strong gas smell.
Anyone have any idea why?
Man, I didnt know that. Geez, doesnt that mean change your oil every 2000 miles?? Viscosity must degrade BAD with that much gas in oil , eh?If SPICA though, it can literally pump fuel directly into the sump.
There you go. This is the biggest reason why SPICA sucks. My project has the same problem. I have a carb conversion ready to go.If SPICA though, it can literally pump fuel directly into the sump.
So it makes more sense to spend twice as much on a Carb conversion than to have your worn SPICA rebuilt (notwithstanding Papajam's admonishment to diagnose first)? Wes is in your backyard - you should at least give him a call.There you go. This is the biggest reason why SPICA sucks. My project has the same problem. I have a carb conversion ready to go.
I've had my Spica system for 12 years now and it doesn't leak fuel into the oil because the pump is not worn-out and it's maintained properly. It's also not had to be adjusted in that length of time.There you go. This is the biggest reason why SPICA sucks. My project has the same problem. I have a carb conversion ready to go.
Actually it doesn't. I just lucked into a complete carb conversion setup for $500. Or I might just get a rebuilt SPICA pump and put the carbs on Ebay. I haven't decided.So it makes more sense to spend twice as much on a Carb conversion than to have your worn SPICA rebuilt (notwithstanding Papajam's admonishment to diagnose first)? Wes is in your backyard - you should at least give him a call.
NonsenseThere you go. This is the biggest reason why SPICA sucks. My project has the same problem. I have a carb conversion ready to go.
Seriously, you should give the SPICA a chance. With a little study and the help of this forum you may find that it's a heck of a cool system.Actually it doesn't. I just lucked into a complete carb conversion setup for $500. Or I might just get a rebuilt SPICA pump and put the carbs on Ebay. I haven't decided.
Actually my last Spider's SPICA pump did fail in this manner. I drove it daily for 9 years, and I checked the oil once a week. One day I checked it and the oil level on the dipstick was way above "full" and I know I didn't add any. It was super thin and reeked of gas too. This pump had about 80,000 miles on it.Nonsense
Oil dilution can occur due to an overly rich mixture (mis-adjusted pump) It can happen with carburetors too. To say it is the "biggest" reason why SPICA sucks is to make a statement that is not backed up by any data or facts. I know the SPICA FAQ posted here says that a worn pump can leak fuel into the sump but go ahead and do a search - this is not a common failure, never has been.
My original SPICA went close to 300,000 miles and never failed in that manner. I've owned Alfas and have hung around Alfa owners, the vast majority of which were SPICA equipped, for over thirty years and have never personally known anyone who had this problem. So no, it's not the "biggest" reason and SPICA does not "suck". It was one of the things that made US spec Alfas stand out. Datsuns had carbs, Alfas had SPICA.
