I need to adjust valve clearance on a 2.0 twinspark engine from the 75/Milano. Centerline Alfa (www.centerlinealfa.com) offers two shim styles: one for "750 or TS", and another for everything else.
Do I need the 750 shims for my engine??
Thanks for any guidance.
Make sure to measure the shims and not assume they are the correct size. Last time I ordered shims from there half of them were way off.
Kevin
Next question --
How can I tell if my current shims are the correct '750' shims? If they aren't, I want to order a full set of the correct type. Got a picture of the two types to compare??
The shims in my engine are 11.4 mm in diameter and have two rings machined around their circumference. Total height is 5 mm.
Mark Joerger
___________
Alfa TS powered Lotus 23B replica
I had some trouble finding official Alfa valve shimes in 8mm, but did find these alternates:
- Older Ducati 'bevel drive' motorcycles use 8mm valve adjuster caps - http://www.ducati-gowanloch.com/ in Australia has a good selection and will ship anywhere.
- Classic Lotus twincam engines used 9/32" and 5/16" cup-type valve shims.
In the USA, http://www.davebean.com/ was willing to caliper thier 5/16" shim selection to find shims that were a few thousandths large to fit 8mm shafts. Their selection is spotty, but they are nice people with which to deal. I got mine from them.
