I need to find out which of these spindles is for a '66 GTV. I'm guessing the one on the right. The car is tucked away, but if no one knows for sure, I'll get it out and check.
I want to add that the spindles are upside down above. This GTV does have Dunlop calipers. I didn't add in that I don't have the '65-'68 parts book, but below is the spindle for the '69 GTV & Spider - along with the two spindles turned around. The caliper mount is cast in on the '69, just as it is in the (now) left one.
Spindles
It doesn't matter which way you turn them; it's still a Dunlop spindle with the pressed on caliper bracket. It's not cast as one unit. The 69-94 style that you see it the book has two little cast ears that hold the caliper, not a straight sided piece. What's the point of your question, anyway?
KG
I apologize, you are correct. I simply did not look close enough to the rear of the unit. Meaning, I'm 'just' missing the caliper mount on the one.
