1 - 11 of 11 Posts
Now, I found a burnt fuse and replaced it , but still have no dash lighting, and shop manual does not specify, I believe. Anyone know which fuse it is and what amps? (a few months ago, that same fuse shorted and dash light , of course, went out. This from condensation drips from ac ductwork, dripping on fuse box!!)
Now I cant remember which one it was. Pulled them all and they are good, but still want to know so I can be sure this circuit is good.
Thanks again for troubleshooting!!
Joe
1. What model year is your Spider? On our '84 the speedo/tach lights are separate from the other instrument lights. At least there is a rheostat (dimmer) for the console lights but the speedo/tach are not controlled by that switch. I don't recall offhand if they are all on the same fuse though. Send a PM to PapaJam and ask if he has a wire diagram for your model year. (I know he has them for the '84 because I have a copy of the diagrams he makes - they are THE best).
2. The cruise control is working great. It is nice to hop on the highway and let the CC maintain a set speed - keeps my right knee/ankle from cramping and probably helps to avoid speeding tickets, too.
Here's a sample from PapaJam's wire diagram:
Discussion Starter · #7 · (Edited)
Sorry for delay....had to eat.
Its an 87 spid. I have a wiring diagram, in the BIG shop manual, but it is not color coded.
I got the thing working, as I said, but too bad these fuse diagrams dont spell it out ....seems too simple.
You would really like the diagrams PapaJam makes. Color-coded .pdf files. You can zoom in on the computer if needed.
I took a copy (on a USB drive thing) to an office supply store and they printed me a color copy on 11" X 17" paper then laminated it. Cost me about $5.00 (I had a coupon, IIRC). Great for use in the garage.
Discussion Starter · #9 · (Edited)
I heard about Papajam.....v good idea....seems like a "gotta have" for sure.....
Does this papajam thing actually match the colors in the alfa system?
Well, you did say theyre the best, so Im sure they are.
Don't forget the dash light dimmer at your right knee. I have had that go bad and used a gym clip to short between the two connecters to check it out. You could easily make a little jumper wire with spades to bi-pass the dimmer.
I ended up getting a new transistor and replacing the bad one. Been working for 5 years now.
Discussion Starter · #11 ·
Thanks, Stan. Yup, that dimmer light fooled me....it was off!!
1 - 11 of 11 Posts
