I was collecting all the tools, bits and pieces to do a porting job and was wondering what are the best bits to get. After doing some searching I found a bunch to choose from at this link but wasn't sure if they are the right ones for the job. Any comments would be appreciated.
Simon, you are talking about porting your Alfa, right ? :D
those carbide bits are way too fine to use on aluminum. they will clog virtually instantly. :(
i don't know if they are the best, but Eastwood sells the correct style for aluminum. they cut fast, and are resistent to clogging from the soft metal :
http://www.eastwoodco.com/jump.jsp?itemID=2338&itemType=PRODUCT
you will also want to use coarse sandpaper on the intake side and fine for the exhaust side to clean-up and smooth down the rough cutting from the carbide bits. something like this works well :
http://www.eastwoodco.com/jump.jsp?itemID=2335&itemType=PRODUCT
finally, you will be using a die grinder or a flex shaft on an electric motor, right ;) a drill motor will not give you the needed control. and, of course, you have done all the appropriate research . . .
Simon: I'd definitely get burs in a ball shape, a taper shape, and an olive shape. The larger balls on pg. two look like they'd work OK but all the shanks look a little short to me. I found mine at a local aircraft/machine tool supply. There are probably several clustered around your airport. That's usually where they are, anyway. The place I used had a good selection of carbide burs and, once I could actually look at what I was buying, I immediately understood what I needed.
Discussion Starter · #4 ·
Dion & Jim thank you for the info.
I'm going to attempt to port my 2L head according to Jim K specs and do a thread on the process. Should be entertaining at the least. :)
Here is a link to the electric die grinder I was thinking of purchasing for the project.
Harbor Freight Tools - Quality Tools at the Lowest Prices
It's a cheap one but I figured I'd only be using it this once so I didn't want to go to crazy. Seems these things go all the way up into the 300+ range. I cant go with air because my compressor is not up to the task.
Simon: The electric die grinder is a good choice, especially if you want to maintain cordial relations with just about anyone within earshot of where you are working. :) Air powered die grinders are l-o-u-d!
Joe Mondello try this from the right man :) realy you dont need more than 2-3 carbide burs .. i use one large + one medium size diamond cut egg bur and one medium size flame burr ... i have ported around 9 heads and 90% off the work is done with big egg shaped burr... other is lots of practice ;)
