Where to test fuel pressure for Spica system
1294 Views 1 Reply 2 Participants Last post by  Bernhard
I just swapped out y 3 port for a 2 port fuel pump. Ran a return line back to the tank. I want to make sure I am operating within range of keeping the pump healthy and engine happy. Where should I install "T's" into the lines to check pressure? And what should those pressures be? I believe that after the pump restrictor outlet I should put one and the pressure should be about 17psi? What about before the pump?
Thanks!
1 - 2 of 2 Posts
1 - 2 of 2 Posts
