For 1976 Nuova Super
There is only one horn currently on car, on exhaust manifold side. And it doesn't seen to be in correct position since it is in the way for easy access to oil filter. How should it be attached? See attached picture.
Is second horn on intake manifold side ... on bracket in 2nd picture? Should it have a secondary L-bracket like exhaust side?
Remove the L shaped bracket and it bolts directly to the bracket spot welded to the car, horizontal, pointing as forward as you can make it. Same on the other side. Normally you would have one high and one low tone.
I don't think that's the right horn either, which is maybe why it's mounted funny. My cars all have FIAMM, metal base, spiral plastic acoustic horn.
On mine both horns are under the battery next to the generator. The relay is a MIXO (sp) not sure of the horn brand but they are the best sounding and super loud. Really sound like trumpets.
