1 - 2 of 2 Posts
Hi,
The self-test shows that the fan speed controller is not working, and in effect we have no heater considering its getting winter here. So I would like to do some troubleshooting, and I've already checked the 40A fuse and relay, however I would like to change out the fans speed controller with a spare one to see if that makes a difference. But I'm not even sure what it looks like, and where it is.
-VARIS
Mounted on a heat sink plate which is fitted into the front of evaporator box a little below where the receiver dryer cylinder is mounted.
You might have to remove top mounting screws of false firewall to move FFW enough to remove it.
Check first square 4-wire connector to it which is usually visible near side of evaporator box straight back from upper engine mount body bolt area.
1 - 2 of 2 Posts
