Thanks, I will check it out if no one is closer!I had work done on my 78 and 86 spider at International Motors in West Haven CT .
Tony the father did the most of the work, pretty reliable and will tell you what is needed.
I had a valve job, engine mounts on the 78, some a/c work on the 86, and they will probably inspect and work on the 86 transmission this winter when I pull the motor on the 86.
Good to know. Do they have to pull the engine to replace the clutch?Any competent shop that works on imported cars should be able to replace the clutch on an Alfa spider. There is nothing tricky or unique to Alfa involved. It would be nice to find someone who has done 100 Alfa clutch jobs already, since they might be more time efficient. But if that requires you to transport your car there and back, going with "Bill's Import Service" might be the better solution.
Yes, I think Woody is done.There is Eurotec in Livingston NJ. A bit closer. For Moorestown, there is/was the Alfa Performance Center in Newportville PA, but I am not sure if they are in business anymore (215 826 9250). I have never used Woody, but have only heard good things about him.
Mo in NJ
A shop that has a lift and a couple of strong guys on hand will just remove the transmission. You might have them look at the giubo, U-joints, pilot bearing, and rear main seal while they have things apart. Plus, of course, replace the pressure plate, disk and throw-out bearing.Good to know. Do they have to pull the engine to replace the clutch?
.... and when you put it back in, you can make sure all the wires are properly re-connected and all the screws re-installed.If you're handy, you can save the shop time and aggravation by removing the console prior to bringing the car. .....
Hello guys,
Does anyone know where I can get a clutch replaced in a 1979 Spider?
I'm in New Jersey but willing to travel to nearby states.
Carl
is rhode island too far?Hello guys,
Carl
What is the giubo?A shop that has a lift and a couple of strong guys on hand will just remove the transmission. You might have them look at the giubo, U-joints, pilot bearing, and rear main seal while they have things apart. Plus, of course, replace the pressure plate, disk and throw-out bearing.
It's the rubber donut between the driveshaft and transmission output flange. It acts to dampen driveline shock and allows for a certain amount of movement. Being made of rubber, it will wear out over time. While it generally won't let go without plenty of warning (vibrations) except in race conditions, a worn out guibo can theoretically result in the driveshaft letting go (with potentially disastrous results including the driveshaft end making its way into the passenger compartment).What is the giubo?
And thanks to all who responded!!
