I've been trying to get the steering wheel out of my gt junior for about an hour today without succes.
I've tryed a steeringwheel remover no luck slidehammer no luck wd 40 nothing.
anyone any tips??
cheers guys
Put the screw-type puller back on and leave it under tension for a full day. Give it a whack on the center screw of the puller when the day is up. This has worked on a couple of stubborn ones for me.
I had one like that. I ended up using a gear puller (w/ the 3 "arms" going behind the steering wheel and middle screw shaft going in the center of the wheel (after lubricating thoroughly, pulling the center nut and disconnecting the horn).
Harbor freight sells a set of 3 pullers very inexpensively. If I remember correctly, the smallest size was the one for the job.
