I'm working on resetting the Airbag indicator light on my 91' Spider. In the housing behind the passenger seat I noticed a red button attached to the side wall. I'll post pics soon but I thought someone might be able to enlighten me on its purpose even without a pic.
Also, I've read the outline on resetting the Airbag indicator light. While watching the light flash for the code sequence(after applying the jumper) I'm having an issue noticing a sequence. My question is, how apparent are the sequence of flashes. I'm watching the light for a break but it seems so insignificant of a flash difference that I think it may be my mind playing tricks. Was it very obvious for everyone else that has had success with this or am I doing something wrong?
Steps I'm aware of:
1. Apply jumper to Black and Blue/Black wire
2. Turn key but do not start.
3. Indicator light should begin sequence 1.2-1.2-1.2 then a difference sequence depending on the code ultimately going back to 1.2-1.2-1.2
4. Once it returns to the last sequence, pull jumper for exactly 3 seconds.
5. After 3 seconds reapply the jumper.
6. After and additional 3 seconds pull jumper again and then quickly pull the key and wait 10 seconds before checking the result.
Thank you all who take the time to help me out!
Steps I'm aware of:
