What's difference (propshaft front coupling)-solved
Does anybody know what is the difference of the "Propshaft front coupling" (doughtnut) of a 1993 automatic spider to others?
I like to get e new one, but don't know the right one.
Many thanks.
1966-2013
Do you mean a 93 w/slushbox vs other years with them, or the difference in general between auto and stick?
There was a thread a bit back that discussed the difference between manual and auto, but I don't recall ever reading about there being something special about a 93 auto. (which isn't saying much really as the topic doesn't come up all to often)
EDIT:
Here is a thread that I dredged up sorta quicklike that has some info about the auto vs manual doughnut/giubo/front coupling that may be of some use.
Thanks, Tifosi,
I check the thread you linked, very informative.
The Drive Shaft Flex Joints for Auto is a 8-hole one, manual is 6-hole.
However, all the Alfa part suppliers only provide 6-hole one.
Since the auto transmission is ZF 3HP-22, same as BMW E21, so I check the BMW parts supplier, I do find a 8-hole one, but they point out the 8-hole one is for manual.
Very confused.
Just like to update the information.
The 8-hole doughnut is available from:
Alfa service (Germany) and AFRA s.a.s. (Italy)
Thanks for posting the update, I will probably need this part at some time so its useful to know where to get it.
