Can somebody tell me what type of webers are original on a 1962 spider veloce? And what type of fuel pump? And are there other items under the hood which differs from a spider normale?
Mars
Mars
I agree with every pointYes, the many variations and confusions in the transition years. My '58 Veloce is pretty much the early stuff but '59 - '62 can drive you nuts. And the literature isn't always a help. I have at least two engine blocks from those years that the number doesn't fall in to any series referenced in Fusi.
BTW, Lionel suggests that 1600 Veloce's all had mechanical fuel pumps. I'd say most but not all. Of the many I've seen about 1 in 4 came with electric, similar to the early cars.
Interesting thread, thanks.
Dan
Lionel needs to add that these were the first generation "large-top" DCOE2's with the brass butterfly bar. There exists a nice second generation DCOE2 "small-top" with steel butterfly bars.
Both are excellent performance Webers.
I am, Gordon. Still learning!Finally, here is a VERY SMALL Weber that has absolutely nothing to do with the above two posts. This is just to see if anyone is really reading this.
Here are some more pictures.
First another missing passage on the DCOE2 SMALL body.
Then a SMALL DCOE2 top on a LARGE body. It does not cover the extra passages.
Another LARGE body passage not covered by the SMALL top.
Then the LARGE body, left, with a SMALL top, and a SMALL body, right, with a SMALL top.
Hello Mars,Thanks till so far..
I have the intention to buy a 1962 veloce ( restauration object) and try to identify if all the correct parts are there ( besides the tachometer, oilsump, correct engine #). Other parts I have to look for?
