So, here is my list of things that need attention on my 94 LS with 86,500 miles.
I am debating on what to fix first although I think I already know the answer. Just thought I would get some input from the BB.
1)Car stumbles at idle and I'm thinking the timing is off...belt change? Costly
*Car is due for a belt change in 10k.
2) Passenger side has a bad camber and pretty sure it needs new control arm and tie-rods as there is a clunk when turning...not too costly...easy fix. Should I do both pass and drver at the same time? May be motor mounts too as at 80 mph on swooping right curve it wants to pull to the right hard with gas.
3)Had a hard start the other day so I'm thinking split hose in tank which would mean replacing the fuel pump, since I'm there already....not the easiest I hear.
4) Still have winter tires on and don't want to run them during the summer..costly.
5) Some rust in the usual areas...to fix it this year or wait till next?
These are the most pressing issues....which would you tackle first?
...note that I am on a budget...so...what ever $2,000 will get done.
Gracias.
Gracias.
