Is the hose which runs from the front filter to the SPICA unit 1/4 or 3/16 or what?
Is it necessary to use fuel injection hose?
Greetings,
I used 5/16" (7.9mm) hose from the fuel filter to the spica pump, and no I don't think you need Fuel Injection hose, the line is not seeing a great amount of pressure.
Surfcity Alfa
Regular fuel hose is fine. It's at most like 17 lbs. pressure. For the hose from the tank to the rear filter to the pump, I use 7/16", not always easy to find.
