Hello Greig
I bought this sprint around 1 y ago as project, is a giulietta 101model 1960 complwted almost
[email protected] ( but need front seats ashtray aiirplane). Is a 1493*21891 came with 1315 and 526 engines outside and installed optional front disc brakes (original brakes also provided) but not calipers....
Ptobably i will add a 1750 AR551 engine, i noted some forums on alfabb,
Some questions
1) do you think is it possible mount 551 engine (using lower support) or does it touch the bigger master brake cylinder that is used with disc brakes ?
ANOTHER QUESTION
2) can i use the normal standard master brake cylinder usually used for brum brakes with the brake disc ?
3) which calipers fit with my brake disc?
Grazie
Francesco
