OK, OK... I know I that there are a pleathora of motor oil discussions, and I truly didn't want to be "that guy", but here it goes...
As some of you may have observed in this thread, I may be taking a warm weather spider across the frozen tundra. She runs a pretty standard 20W50 oil, which a lot of people like on the bb. It is entirely possible that I will have a couple of single / double digit starts before I return to a more moderate climate.
So, two questions. If I keep the 20W50 in the car, what concerns should I have, especially with that first start in the morning? (I assume once the car is at running temp, I should be ok).
If I were to give it a quick oil change before I go, what weights would you recommend? Would you also recommend changing back to the 20W50 when I get back? Also, considering I can check the oil every 3-4 hours, would this be a great time to try a synthetic, as I can monitor if I'm losing any oil pretty closely?
OK... so that was four questions... thanks in advance for your suggestions!
