Sorry if this has been asked before..couldnt find it...and other than finding a 3.0L , what engines? I'm talking about the 81-86 GTV6 of course...can any models from the 90s be fitted in? Where would one go about finding possible engines...I found a bunch in ebay but from the UK (makes sense), im from california
How much $$$ do you have to spend? I once saw a Maserati V8 in a GTV6..
The simplest engine is the 3.0 from the Verde, it's pretty much a bolt in.
Any of the 2.0 variants will fit, that motor came in the Alfetta. But now you're looking at parts - headers, fuel system, ECU, etc.
The 2.0 TS from the later cars would be a nice swap, imo, you're still looking at parts, but that motor came in the Milano (75) in Europe, so it should be readily available. Depending on what you do, you'll end up with similar HP to your 2.5, with around 100 fewer lbs over the front wheels. If you've ever driven an Alfetta, there's an appreciable difference.
Any of the 3.0 variants from the 164 can be made to fit, but there are issues there as well, sump, intake, etc etc. If you opt for the 24v, you need to fabricate headers as well.
Personally, I think the 3.0 from the Verde is a great update to a GTV6, if you're looking for more than that, it's going to start costing you $$$. For any 163 3.0 variant (with the exception of the 24v), I'd think it would be just as easy to build a Verde motor to 164 specs, as opposed to making the 164 motor fit. A lot of the effort in making the 164 motor fit involves finding Verde parts anyhow..
HTH,
bs
