And where does it connect?
I can't seem to locate it on my wonderful papjam wiring diagram....it could certainly be user error.
Thanks, JP
That's the low pressure cutoff switch, meaning the switch will close and power the compressor clutch once the minimum system pressure has been reached (seems to be ~ 5-9 psi). However, the switch you have is not OEM original; somebody found a replacement, likely because the original switches fail over the decades and no longer make consistent contact when pressurized.
I've tried pretty hard to find a replacement for the OEM one in the USA, but have not found a source. The thread pitch is different than most other switches with the same thread diameter. Thus, I keep the switch wires permanently jumpered with a piggyback spade connector.
The standard Montreal wiring diagram does not address the A/C system. The one that claims to cover the A/C is not 100% accurate. The official early Alfetta wiring diagram (with A/C) gives the best representation for the Montreal's A/C system, as the two are very similar.
Finally, a good belt size is a 10mm wide x 975 mm long belt (x2), which will put the compressor just past the midway point of its slot free travel.
Thanks for the feedback, Hans! I appreciate the info.
Alex, let me get back to you on the switch. I am going to a more modern Sanden compressor so may have a different interlock to tie in to.
JP
