1 - 17 of 17 Posts
As I said in other posts I am new to this car, so looking at my pictures could someone tell me what the black cylinder thing that sits to the right of my air bo
Also notice on the what I will call the ram tube coming out of the air box the circular thing that looks like it should have maybe a vacum hose but if it did where would it lead.
Is there a manual I should own that will help me identify the different parts that I am having trouble with. Replaced the air filters today for that bottom clamp, wish I had smaller less arthritic hands
Its a 79 Spider.
Those pictures aren't real helpful. They are too close up to tell what you are really looking for.
Look thru the FAQ at the top of the forum and you will find lots of interesting info.
when you say black cylinder thing, I guess you mean that cylinder thing, almost out of shot, top centre your first photo?.....if so that is your OVS (Oil Vapour Seperator).......you should remove this and thoroughly clean it through with brake cleaner spray...........you will prob. find all sorts of junk fall out of it. It is part of the crankcase breathing system and can get real messy inside (if it hasn't fallen apart altogether inside!)
The small "hose outlet" on the airbox: the photo doesn't really show where it is........at a guess it is one of these, as described in this thread:
http://www.alfabb.com/bb/forums/carburetors-fuel-injection/25018-spica-airbox-hose-question.html
Discussion Starter · #5 ·
oil vapor seperator
I think from looking around the site that is what it is. My next question what purpose does it serve and do they need to be replaced at certain intervals
I think they recirculate/direct the oil vapors that occur when oil is heated up, into the intake manifold to be recycled/burned in the combustion chambers. Its kindalike a emmissions item.
If my explanation is not exact, other well knowlegeble members here will correct me......
That would be the TAC (Thermostatic Air Cleaner) vacuum motor. A temperature sensor in the air cleaner sends a vacuum signal to the TAC motor which then blends cold intake air with warm air from around the exhaust manifold to maintain engine intake air temp to about 104F.
Is there a manual I should own...
Please send me a private message with your email address and I'll send you the 1979 factory Alfa engine maintenance manual. It includes systems descriptions, Spica and ignition stuff.
Papajam does it also have an influence on the secondary points? I wonderd about that cause it hooks to the connector to the distributer. Can you also send me this diagram?
My 79 had this unit in it and wish to learn it's function
Yes, I thought it was the spark retard vaccum switch for dual-point Marellis distributors of the smog era. Most are disconnected/broken by now, but some still function or are present even if not functioning.
And it's not to be confused with the often problematic fuel cutoff switch that is there to protect you in the event you should find yourself upside down. Like it would help at that point.
We're talking two different devices.
The second pic shows the front of the TAC vac motor (and the vacuum hose fitting). The off white plastic device (with the red hose) in the foreground of the first pic is the vacuum switch for the ignition system. This vacuum switch, when sensing low/no vacuum (high engine loads), engages the secondary set of points in the distributor which retards the ignition timing a few degrees.
Both the TAC temp sensor and the ignition vacuum switch use the same manifold vacuum source.
Oil Vapor Separator
Here's a picture of an Oil Vapor Separator removed from the car. This one has, of course, been cleaned and repainted.
Auto part
Well if you are upside down in a stock Spider with no roll cage....being on fire too probably won't matter because your head and spine are crushed and likely you'll not feel a thing! But good to know it's there lol
1 - 17 of 17 Posts
