1 - 19 of 19 Posts
Hi there,
I saw an engine fitted into a 105 gt coupe.
I can't figure out what is the engine. A 2 liter ? US market ?
The number stamped on the block (rear, driver side, near the gearbox) starts with AR 00550 ....
Tha engine is fitted with dellorto carburetor.
Thank you for your help.
Chris
are you perhaps misreading it?
AR00551 would be a USA 1750
AR00559 would be a 1300 GTA junior engine, but you will have noticed that one as it will have twin plugs:)
not sure what AR00550 is
According to Fusi, there's no 550 engine code (at least until 1972).
If it's 551 it's a US version 1750 originally fitted with Spica injection.
Sent from my GM1913 using Tapatalk
Thank you for reply.
Yes I have the fusi, but can't find a 00550 code....
maybe it's an engine after 72 ?
Any markings on the front of the cylinder head? Square or triangle or triangle with a dot or plain 2.0.
I made a picture, but not very clear (sorry).
I compared with the 3 of the number which is after and the beginning looks like 2 figures "5"
1609887
On the cylinder head, there is a square, but I did not see if there is an oblique line or not
Here's the versions. If it's post 76 it should be plain 2.0.
but the life of alfa is often hectic, so the cylinder head may not be original. I confirm a squere, but not sure 1600 or 2000...
Later 2.0 eg from a late S2 spider are AR01615 though. At least the US version.
looking at your photo I can see a '6' (not a zero) before the 55
My new guess therefore is:
AR01655 then the serial begins with a zero: 023679
and that would be a 2.0 litre from a 116 Alfetta or 116 Giulietta (from about mid 1970s through to the mid 1980s)
with dellortos it will be EU, not USA
Discussion Starter #13
Not agree.
Look at the 6 in the serial number and you will find that the figure before 5 is 0. The first two figures are 0.
Yes EU engine, but strange number type for me...
Or maybe it's 0530 (more correct). I have to check again, but I'm not close to the car.
Chris et al
Those are not Alfa engine stamps..... it's a home stamping job
Compare it to your own cars stamp fonts and you will see the difference
Aye
Greig
Discussion Starter #19
Agree, the number is home made.
But what they have choosen 0550 and not 0512 ?? Where can this 0550 idea come from ?:cool:
Anyway, we started the restoration of the car and the engine is definitively 2.0 liter.
Chris
1 - 19 of 19 Posts
