Yeah, that's normal. All three of my Alfas burn/leak a quart every 1-1.5K.
Alfar Been through the "what modern oil to use" conundrum a number of times with older cars.Mobile 1 isn`t an oil for Alfa engines.
The oil is both low in ZDDP and the nature of synthetic oil with smaller molecules do not offer adequate protection for the cams or cam followers.
As well it is the smaller oil "molecules" that cause all synthetics to leak far more than conventional oil.
I suggest you switch to Valvoline 20-50 non synthetic
and you will find it will leak less and burn less oil, as well protect the engine better.
Synthetics are fine for modern engines with roller valve actuation but not solid lifter motors.
Based on the info about Castrol removing ZDDP discussed in other threads here on the BB, I am now running
GT-1® High Performance Motor Oil with Liquid Titanium®
which contains ZDDP.
Attached is an image of its container so you can find it more easily on the shelf. FYI Amazon stocks it.
"Liquid Titanium"Based on the info about Castrol removing ZDDP discussed in other threads here on the BB, I am now running
