1 - 10 of 10 Posts
It is a Autodelta, Siamese linered 16 Valve engine from the period, looks as if the 4 spark plugs 10mm Dia are not fitted, very rear as not many were fitted to 105's. Has got the correct slide plate injection
Cool, thanks. I wonder what's the displacement: if he declares 220 hp I suppose that it should be a 2000 cc
if it raced it must have ran in group 5 if it had the 16 v engine , on the trink they put a 1.8 script if i am no t mistaken . it is probably a 1750 engine. the body being a sprint gt and this engine would have only enabled it to race in gr 5 in the mid 70s .
The engine is an AUTODELTA 16 valve originally built in the 1960's. It seems that there were different engine capacities 1300cc, 1600cc and 2000cc.
It seems they proved to be less reliable than the 8 valve 'testa stretta' of the same era.
1 - 10 of 10 Posts
