Hi,
Was changing the oil in the 69 spider, and noticed on the
dip stick tube, just above the clamp that it tees off into a hose (tube) barb.
It had a cover on it like you would use for a vacum connection you weren't using.
Is this original to the 1750??? Should i just leave it plugged or is there a line that should be hooked to it and where does it go??
I'm confused
I'm confused
