3861 - 3880 of 3943 Posts
Moderator
@ Vivace. I don't know. I made no changes to the differential internals.
I simply pulled the bolt, yolk, sump pan and drain plug off, removed the seal, degreased all sealing surfaces,
then installed the new seal and pan gasket and sealed the threads of the drain plug, nut and spline with Permatex Ultrablack.
Tightened the nut and re-peened it with the original alignment.
Let it cure overnight, then refilled it.
No leaks 2 weeks on.
Moderator
Removing the bolt requires an Alfa tool to immobilize the shaft and
a castellated socket to remove the nut.
I was able to slide the yolk off with only a little effort.
Bicycle part Auto part Rim Metal Wood
Cylinder Machine Metal Auto part Electronics accessory
1999 Mercedes C43, 2003 SL 500, 2000 BMW 540/6 , !981 Alfa Spider
HMMMMM... I stared at it in the garage and wondered why, even with the interior removed, for the last 9+months I haven't been able to get my heater box out?
Reactions: Bern1
Love those wheels!
Thank you. It only took me 25 years to track them down. They were available new through Alfa Ricambi in the mid 90's. They are 14x7 instead of the traditional 14x6. Could have bought a set at that time but did not. I kicked myself when they were all sold out. I recently found a set so I bought them right away.
Reactions: Vivace
Reactions: joelynbeach
Tank out, yay. Get this - still fuel in in after over 10 years stored.....(?)
Doesn't smell good, dark orange...but it burns. And it obviously has no holes in it. Pretty shiny inside with some varnish. Off to the radiator shop for cleaning.
Wood Automotive design Gas Circle Tints and shades
Motor vehicle Hood Automotive design Automotive exterior Automotive lighting
Automotive tire Motor vehicle Automotive exterior Bumper Gas
Automotive tire Tire Bumper Motor vehicle Wheel
