3461 - 3480 of 3542 Posts
worked on down pipe.. cut a slender section out and heated it up to bend a little..... weld weld the cut sections tuesday, then blend the welds as best i cam.... cleaned up some welds
Replaced original shocks on Monday also. Only 33 years old. Really tough to remove the lower nuts, to get the old ones out.
John
Reactions: vbisbest
Replaced my old, dirty over flow tank and cap with a nice new one from Classic Alfa. Looks muuuuuuuuuuuuuuuch better now.
1683587
Also replaced my worn out shift knob (couldn't see the shifter numbers anymore).
1683588
i had thay done to my old oem dash a few years ago.. red stiching... gave the dash to a freind
camera for my phone. so i can look inside things...
Alfa Romeo Spider 2.0, Alfa Romeo 166 3.0
Removed the OVS yesterday for the first time since i bought the car in 1995 and was surprised that i could blow in the top hole and both passages on the bottom let the air out easily after all reading about clogged OVS. Doesn't look to bad either, so we'll see how it looks once i get the gunk out.
1683903
1683904
1683905
what I do is cut wine corks to tightly fit those big holes, fill it with cleaning fluid of your choice, then shake the heck out of it with my finger blocking the small tube, empty and repeat several times.
remember to squirt 20cc of clean engine oil into the small hose that goes down to the block when putting it all back
My goal is to polish the back window after every wash. When I purchased the car the back window had hundreds of fine scratches. This seems to help! In truth I probably polish the back window once a month. The photo looks better then real life. You can use any polish and even a machine if you want. I polish by hand because I am to lazy to tape of the top. When you use a machine the polish will sling on to the fabric of the top. If you do have deep scratches make the effort to polish the first time with a machine.
Ken
Did is simple but satisfying job. Polish my back plastic window.
Ken
My garage is used for a ton of projects, but my spider get parked in the garage ever night. In California Hagerty insurance requires that you park your car in a lock garage. There are exceptions like if you going on a weekend trip or etc.
Ken
Replaced starter and fired up my 71 for the second time. Needs a tune and sorting out of some lighting gremlins, bu tleaving htat for the experts. Next Ill tackle touching up the paint chips
Reactions: pantera928
see my ecotec conversion..did not want to talk up to much space here
