Well... had I anticipated so much cutting of stuff, would not have started but once in, finish. So, almost got the 2 din stereo in place. I had to trip the upper part of the console under the vinyl) for lower clearance and widen the back of the middle plastic shroud for the stereo itself. The hardest part was lowering the stereo shelf. This piece must be retained as the center shroud (as I call it.... the plastics under the stereo face and environmental controls) is bolted from the top. The lowering of the plastic at the front-top of the console required removing part of the plastic, and one metal plate that ran left and right as support. This was very touch mental to drill through and I had to grind part of it.
The stereo shelf required lowering as well so I cut that across the top and lowered the top section into the bottom section so I have a proper support for the unit and still have the mounting points.
A bit more trimming and re-gluing the vinyl is next, plus make a new let-right support for the top of the console, under the vinyl, so the vinyl does not sag.
Then, finalize the shelf position, add 2 rivets to unite the top and bottom sections, make 2 new mounting points (as the plastic section with 2 existing points was cut off) so nothing gets creaky at speed, wire up the unit.
There were a few missing screws and bolts under the enviro unit which explains why there were so many creaking sounds out of the dash. Really annoying.
Picture 1: set in but not connected
Picture 2: stereo shelf before alteration (I will post an after shot later), the shroud is attached via to bolts at the front holes and 2 at either end at the bottom. the shelf is attached with 2x 10mm bolts and is also slotted.
Picture 3: The stuff under the ashtray. gentle goes it as the plastic will crack. You are seeing the ashtray cover, 2 springs, the removed plastic ( middle) and the ash tray frame, the top which has to be removed. The frame is then put back in place to add rigidity to the top of the console.
