Strange, the carpet underneath the passenger seat in my 92 Spider Veloce is wet! The car has rarely been driven in the rain until recently, so this is the first time I noticed it. There are no apparent leaks anywhere. Is there some way water can enter undercarriage? Hate to ask a dumb question, but I am stumped. Anyone experience this? Thanks.
It is likely from the cowl drain tube. You can start with this and if you want to read more do a search on "cowl drain" in the spider forum!
Similar problem with my 72GTV. The only way I solved the problem was through a complete inspection of all entries from the firewall into the passenger comparment. I found missing and cracked grommets in the firewall, rotted fresh air ducts, split cowel drain hose and a 1/8" hole drilled into the cowel right above the passenger compartment. I was able to fix all of these problems with parts from either IAP or McMaster-Carr.
