21 - 22 of 22 Posts
If you check the voltage on that wire when you turn the ignition switch to start, it is better if you can do it while it is connected. A high resistance in the ignition switch or in a connector in the circuit will show 12V with the wire unplugged from the starter but very little voltage when it is connected.
Discussion Starter #22
Update: So it turns out issue was with my starter. I swapped it out for a new one and haven't had an issue since.
1604103
21 - 22 of 22 Posts
