How does the throttle spindle seal where it goes through the carb body?. Does it just seal on the bearings at each end?. Are they easy to change?. I figure mine must be worn as I seem to have an induction leak on number 2. Used the LPG down the carb trick to find the cylinder responsible. All the vacuum hoses are air tight and I think the shaft might be a bit loose.
Any suggestions?.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
Alfa Romeo Forums
