I'm unfamiliar with Alfetta's, but might one be made from a partial cold air box backing stamping?
The carb dimensions should all be the same, right, as the carbs all fit on the same manifolds.
I have a flat piece of alum with the holes properly drilled, can post a pic to see if it it might suit you. It was the basis for a support plate but was never finished. Shipping to you would be $$.
This is the way I used to do it Andrew. You can buy a plate from several of our good suppliers.
