1 - 5 of 5 Posts
1967 Duetto Spider
I want to reattach the choke cable to my Webers, but realized the bolt that holds the cable in place is missing on the right side carb. (Here's a picture of it on the left side carb). I can't find it in my jelly jar of wayward nuts, but where could I get one?
1677219
Looks like Pierce Manifolds (piercemanifolds.com) has what you need if I'm looking at the right parts.
1677225
Beware: you need pixie-sized fingers to be able to attach it, though!
Yes. After doing that operation once, I learned to set up my choke cable before installing the carbs all the way onto the softmounts. That is, position the carbs on the ends of the softmount studs, hook up the choke cable and then push them home and install the nuts on the softmount studs.
I bought two awhile back. The hole drilled in the bolts were
off center so one broke. Finally found some NOS. Much better.
I got into a conversation with a major Weber seller.
He said that the "enrichment" thingy was not needed.
This proved to be not true. Much better with it.....:)
1 - 5 of 5 Posts
