21 - 37 of 37 Posts
back to topic, my understanding is that with EmCon carbs you can not interchage E.Tubes like in the older ones, it doesnt work that way, like the tube has a lot more and bigger holes for the transition phase, older ones doesnt have this feature, stick with the original ones and play with the fuel and the air
Weber had many features for emissions carbs. Some carbs had all of the features but others only had a partial set.
These features include:
Feeding the progression circuit from the well rather than the float bowl.
These required different emulsion tubes, usually F34 or F41 which are interchangeable.
They also required type 2 idle jets, typicaly F21 or F17
4 or 5 small progression holes rather than 2 or 3 larger holes.
Idle mixture screws with a narrower taper, more than one design
Air balance screws around the throttle plates.
Larger auxillary venturis which extend the progression range and bring in the main jet at higher rpm.
Many emissions carbs required larger main jets than classic carbs with the same venturi size.
The carbs in question here are 40DCOE44/45. They have "classic" progression plumbing and use "classic" emulsion tubes and idle jets.
At part throttle up to about 3000 rpm, idle jets have the most influence.
At part throttle and higher rpm main jets have the most influence.
At WOT main jets and air correctors have the most influence.
Certain emulsion tubes work best with certain cars. 4 cylinder Alfas always had either F9 or F16 unless they were emissions carbs. I have experimented with F9 and F16 with data logging. F9's are marginal at high power and rpm and tend to run lean. To correct that you have to install bigger main jets and that makes the mid range too rich.
A float level that is too low will cause leanness, particularly in the transition phase. One that is too high will cause richness .
Discussion Starter #22
very interesting alfaparticle! so you would recommend F16 over F9, right? Thinking about float level, I did correct it in when changed the jets to early 2000 ones. DCOE 44/45 have 7mm, and CDOE 76/77 have 7.5mm. I'll try to put it back to 7mm and that should enrich the transition
Ludo
0.5 mm should not make much difference.
A friend - 65Sprint, asked me to drive his car and tell him what I thought about it. It had a flat spot around 4000 rpm. He thought that it was lean and he was using larger than normal main jets. I lent him my wideband AFR and he found that it was too rich. He was then able to eliminate the flat spot by installing smaller jets. Even experienced drivers can find it hard to distinguish between an overly rich and an overly lean condition.
What size venturis (chokes) are in your carbs?
Discussion Starter #24
32mm (DCOE 44/45 is normally 30mm). And you’re right: I may be too rich as I went back to std set up (117 main jet, 180 air jets and F16 tube), and transition
was much better. I also checked the cams timing, and it seems my exhaust valves are opened 0.15mm too high at BDC. So I probably have a bit more valve overlap than it should. I’ll correct that tomorrow and see the effect. But in any case I think I now need a rolling road and check my air/fuel ratio to make sure my engine runs properly
model 44/45 is an EmCon (Emision Control) carb idd for 1.6 so you have to stick with the original E. Tube otherwise they are never going to work properly. Normal DCOE´s (No EmCon carb) use a total diferent E. Tubes, so the E. Tubes are not interchangable between EmCon carb and No EmCon carb (any number above DCOE32 is an EmCon carb)
Nearly right. 33's, 34's, 35's, 70/71's, 90/91's aren't true Emission Control carbs either.
We have an Innovate LM 2 with the tail pipe adapter. Has anybody had luck with these? or is it recommended to drill/weld the bung?
My buddy used an older model than that for years and loved it.
The bung would be faster reacting, but at this point not crucial.
Any measuring device is a great tool in determining your jetting needs.
It's the most accurate and efficient route to take.
I could give you my jetting specs but they're not necessarily gonna work for you. It's all a guess, and i suspect you don't need any more guesswork.
I live at 5300 foot elevation. What's your elevation? These are factors that can make or break you without proper diagnosis.
Push hard and live
I recommend you try a set of Keith Franck’s “VF” tubes before you get lost swapping emulsion tubes.
Also, make sure you’ve got at least a 33 Venturi. With hot cams, I’d try 34 or 35 at least, but WITH the VF tubes.
Last night I was able to spray some starting fluid around the carb soft mounts and the engine speed increased and smoothed out. Seems as new soft mounts are the next step. Centerline has them for $25./each, it sounds like a no brainer. I also connected a vacuum gauge and the needle was bouncing all over the place, telling me a vacuum leak. If vacuum leaks exist, I don't think any amount of carb tuning will provide the desired result.
Exactly. Nice find.
Thanks, back to the basics. If all the systems are not correct fooling with the carbs is a waste of time.
Hoping to get this issue cleared up and then on to setting the Webers up. We have an Innovate LM 2 with the tail pipe adapter. Has anyone had luck with this setup? I have never used it, but does look somewhat confusing. We will not be using the OBD function or the RPM function.
Does it have a way to just monitor air/fuel ratio? Commonly referred to as AFR.
capturing the AFR and RPM simultaneously is highly desirable
I would say it is essential for setting up carbs. Even on a dyno where you don't have to steer or brake it is hard to determine at what rpm an AFR dip or bump occurs by trying to simultaneously monitor the tach and the AFR readout.
Push hard and live
Cheap soft mounts are very expensive.
Buy the best quality you can find.
Trust me on the Franck VF tube concept. Changes the entire thinking around Webers. Frankly, his explanations suck. But the tubes work.
I have an Innovate AFR and use it both bung-mounted as well as with a tail pipe adapter. The tail pipe adapter can be less accurate at idle due to reversionary air flow contamination.
But under driving conditions I’ve found both mounting schemes provided consistent info. Makes tuning carbs much easier.
21 - 37 of 37 Posts
