I have recently bought a pair of Weber 40 type 2’s to fit to my Series II 2L Spider - the plan is to have a normal street car which will also be fun to drive on the occasional twisty road.
I have read several posts on Weber 40 DCOE jetting and have managed to answer most of my own questions, but I am still a little confused by the idle jet settings.
The carbs came with the following:
Choke 30
Secondary Venturi 4.5
Main jets 125
Air correction 160
Emulsion tube F7
Pump jet 40
Starter jet 65F5
Inlet/Exhaust valve (in bottom of well) 50
Inlet needle jet 175
Float 26g
But the idle jets are a mix of 55F8 and 45F8 - one of each in each carb.
So my question is whether I should buy 2 more 55’s or 2 more 45’s, or just average it out and buy 4 50F8?
Many thanks to all those whose posts I have found so helpful - especially Gordon Raymond, AlfaParticle and Alfa7.
Kind regards
James
1972 Series II Spider
1974 2L GTV
Choke 30
Main jets 125
Air correction 160
Emulsion tube F7
Pump jet 40
Starter jet 65F5
Float 26g
Kind regards
James
1974 2L GTV
