HI Guys,
Has anyone purchased new weber carburetors that are made in Spain. Model 40 dcoe 151.
The standard set up for these carbs from the supplier.
Standard Jetting:
• Venturi / Choke : 30 mm
• Main jet: 115
• Emulsion tube: F11
• Air corrector jet: 200
• Pump exhaust valve: 50
• Idle jet: 45F9
• Pump jet: 40
• Needle valve: 1.75
• Starter Jet: 85F9
• Starter Air Jet: 150
I noticed on the Centerline website a data sheet that lists the recommended setup for your car model. For the 2000 they have two options. Which is best suited for these 151 carbs? Data sheet attached.
I have only changed the main jets to 130. Not much difference in how the car drives. I would say a bit better.
My car has a rebuilt engine with high compression pistons, CB road cams, euro setup with euro manifold.
Just trying to get a bitter sense on what I should consider buying and switching out.
Standard Jetting:
• Main jet: 115
• Idle jet: 45F9
• Pump jet: 40
• Starter Jet: 85F9
