Lets address this to Alfa production cars;
The roll axis is only a straight line between the front roll center and the rear roll center. It`s effect on handling is a function of how different those roll centers are. It`s not a real factor as to handling, but an indicator of the disparity between those roll centers so they can be optimized based on "center of gravity" at those two ends of the car. And they are very different.
If your race car had equal height roll centers torsional flex wouldn`t be stressing the chassis as much as low front, high rear. But the location of the roll centers on all alfa production cars isn`t blessed with that.
Using dropped spindles, which allows raising the lower A arms outer position, (and raising the top arm mount on the spindle to farther increase the angle of the upper arm on race cars) will raise the front roll center. That is critical as the front of the car has a high "center of gravity" and far more mass there than the car is carrying at the rear.
At the rear the suspension design as the factory accountants controlled (Trunion) causes the axle`s tire loads to be shifted severely to the the outer tire unloading the inside tire. With the roll center positioned in the center area of the axle See pic of mine on the Duetto and the Coupe) the force and load on the rear axle using a Panhard system designed so that the it`s axle`s pivot mount point, and the chassis pivot mount point is basically a straight line, and it`s upper link is angled downward appropriately, then you will have less unloading of the inside tire. This because of the axle`s upper arm`s reducing weight transfer to the front under braking and increasing axle load under acceleration.
But there`s more to having a great handling race car. With significantly stiffer front springs and sway bar, more of the front weight is transferred to the inside rear during cornering.
My observations regarding what works with Alfa race car set up:
Front: Dropped and raised spindles. 1200-1300 inlb spring rate. Stiff shock settings, Droop limited to 1.5" at the wheel
Rear: Properly designed Panhard and upper link position. Softer shock setting, 150-160 inlb spring. NO Sway bar, softer tire pressures .
