Is it possible to remove the water pump without removing the crank pulley and without sawing off the bolts? I'd like to avoid that if at all possible.
If not, what's a good way to keep the engine from turning when you remove it? I've been told to put the car in gear. Minor problem is that the engine isn't in a car, it's on a stand. I've also been told to block the flywheel.. once again, a problem arises-- there is no flywheel to speak of.
Thanks.
Thanks.
