Thank you Velocewest...Velocewest said:Alfa Chan, can you be more specific -- what model and year of car are you inquiring about? On my 74 GTV, there are 2 pods of lights between the tacho and speedo. The left pod has the lights for Hi beam, brake warning, low oil pressure and the parking brake light. The right pod has the turn signal indicator, the alternator light, the low fuel pressure light, and the heater fan light. There's also an indicator light for the hand throttle.
THX!!Keven said:Alfa Chan the lights are for fuel pressure,
parking brake, headlights high beam, and parking lights.In that order from left to right.
The fule pressure ligh should blink a couple
of times before when the ignition is cranked.
They are from the factory.
Hope this helps.
