I know this has been discussed many times on here so I apologize in advance for asking this but I couldn't find it with the search function.
My 77 Alfa has 4 warning lights in the middle of the gauges. two red on top on either side of the oil gauge, a green on the lower left and blue on the lower right. I know the blue is for the high beams.
What are the other 3?
Thanks in advance for your reply.
Ventura Alfa
5 Hours...hmm
Red= Low Oil pressure
Red = Fuel Pressure ( the one that goes out soon after key is turned )
Green= Parking/ Low beams
78 Alfa Spider
Top Left Red = Low Fuel Pressure (the one that goes out (should) soon after the key is turned) If it takes a few seconds for this light to go out you have a fuel issue that will need to be explored.
Top Right Red = Low Oil Pressure. Will stay lit until the engine starts. If this lights when the engine is running, turn the engine off immediately. Light will illuminate when pressure is below 3lbs or 5lbs. I don't remember which.
Green = Lights
Blue = High Beams
