My brake and battery warning lights come on momentarily and fade out as they should when the Alfa is started up. But when I'm driving, they will do the same thing or flicker on and off when I go over the slightest bump..
1) I've cleaned and tightened the battery posts.
2) cleaned the grounds under the left corner of the dash. (4 wires)
3) cleaned and tightened the battery negative cable connection to the car.
Any ideas on how to fix this. It's a little annoying.
