wanted later g/box transmission mount for 750 B series.or the measurement from the top where it bolts on to chassis to the centre of the bolt hole,as i can then adjust 105 mount.Bill
I had a friend who owned a 1959 Spider with a tunnel cast transmission. He used a 105 1600 transmission and had to make a larger hole in the body to fit the transmission. He also had to change the transmission bracket and made his own bracket. I put a 105 1600 in my 101 Sprint Veloce using a bracket that I purchased from Alfa, but I do not know if that bracket would work for a 750 car. The transmission bracket holes might not be in the correct location.
Hi Kuni,i had to put a new tunnel in and i cut a hole for the later g/box which luckily worked out fine,i just need the depth from chassis to the hole for the bolt ,the holes for the bracket are correct.Bill
