I'm wondering if this little black box under the dash is causing an overheating coil and misfire. If anyone has one they'd like to sell please contact me.
1604394
That box only controls the timing of the trigger pulse. The ignition module that is mounted near the coil is a more likely suspect or the coil itself.
Yes, but I believe it also controls dwell time to the coil. Excessive dwell could overheat the coil? Also, using a timing light I've noticed very erratic unstable movement of the mark. I know the distributor is good, had it rebuilt.
Still looking for this little black box. I replaced the coil and spark module below it, and ignition wires. Runs much better, but timing fluctuates at steady throttle.
