On sending units, old ones to me are usually suspicious. I would just get a new one from Centerline, Jon Norman, whoever. Berlinas have two tank sizes, with different depth senders (arm length differs). A 74 probably has the smaller tank and shorter sender, same as GTV or Spider. If you have the deeper tank, you can use the shorter sender, but not vice versa, unless you bend the arm some.
