1 - 5 of 5 Posts
Need 91-92 164 front left signal lens (clear). Rather not have to source an entire headlight to get one. PM me please.
So you have a CDN spec 164? What headlight system do you have Carello or Elma? Carello was USA spec so parking and turn signal light assembly can be removed from headlight. If Euro series one Elma the turn signal lens is part of headlight but can be replaced.
Lens is glued onto the Carello parking and turn signal assembly body which is separate unit from headlight assembly. It takes a dual element 1157 bulb.
The Elma turn signal body is part of the headlight and uses single element 1156 bulb and yes turn signal lens does snap lock onto headlight body.
Just trying to be sure which type you need since you stated turn signal lenses.
Canada cars are the same as US cars except for DRL relay under the rear of the centre console, dual unit speedo km/mph, odometer and trip in km only and bilingual French/English labelling.
1 - 5 of 5 Posts
