To see if the injectors are working?
Look at the spark plugs for free.
To see if the injectors are working properly, they need to go someplace like OK Injectors for testing/inspection and if desired, servicing.
Or you can play that game with the jars with measurements on the sides where you take the rail off and spray them into said jars to check volume over x amount of time, then get a pressure gauge to check pressure in the rail.
