The first thing to do is to inspect bushings and linkage pieces for any wear as it can cause the problem you are describing. In fact, if it shows much wear, you should go ahead and rebuild it even if it is not THE problem you're chasing now, as the improvment is huge.
Another possible culprit could be (extremely) worn transaxle mounts.
Internal damage to reverse is possible, but less likely than external causes.
A Gold transaxle has a 4.10 diff ratio, vs. the 3.55 ration in the Verde. It also lacks the LSD found on the Verde and Platinum models.
Joe
Joe
